TwinTurbo.NET: Nissan 300ZX forum - Like. However, if he has to rotate the screw back & forth
Zuberman
on June 23, 2015 at 9:53 AM
Teflon tape ? (n/m)
posted by ttz'in (norcal)
on June 23, 2015 at 05:49 AM
to make adjustment, the tape may "ruffle" when turned against the last wrap. Maybe there is some way to "adhere" the end of the tape's last wrap to itself so it won't "ruffle" (??)
Leaking idle adjustment screw.
Tanley
21:03:47 06/22/15
Re: Leaking idle adjustment screw.
Zuberman
04:10:52 06/23/15
Thanks for the link! I don't believe the seal can be
Tanley
05:29:15 06/23/15
Teflon tape ? (n/m)
ttz'in (norcal)
05:49:21 06/23/15
Like. However, if he has to rotate the screw back & forth -
Zuberman
09:53:08 06/23/15
Thought about that. Usually 3-4 turns out will get
ttz'in (norcal)
18:11:16 06/23/15
Oy! What an odd little bugger! :( I think you're correct:
Zuberman
09:59:49 06/23/15
I just did a leak test with smoke.
pieboy100
12:00:51 06/23/15
I'll let you know if I can get it to seal up, but I think it
Tanley
12:50:12 06/23/15
No dice. The silicone spray softened it too much and made it
Tanley
19:08:12 06/23/15
Use pipe dope. It never hardens. (n/m)
flashstar
02:10:39 06/24/15
Perhaps just one of those many things that we have to break
Zuberman
07:10:08 06/24/15
Yep, got 20+ years out of it, not too bad.
Tanley
16:20:08 06/24/15
Not sure about fluid resistance but this stuff seems
flashstar
16:33:21 06/24/15
Have a few extra IACV's if that helps ?
ttz'in (norcal)
16:16:11 06/24/15
A+! :) (n/m)
Zuberman
01:49:49 06/25/15
